EAGLE User Support (English) Tiny air wire scraps
  • Subscribers 177 subscribers
  • Views 293 views
I seem to be plagued with numerous tiny air wires
on a board I'm trying to finish. These have the
appearance of being "embedded" in the pads of
SMD components. Ripping up and re-routing doesn't
get rid of them.
(But all of the copper trace connections seem to
be OK.)
I'm guessing that the library SMD parts I'm using
for some reason are not on the grid (??!!), but I
don't know any easy way to fix this. I've tried
using both metric and English measure -- didn't help.
SO, I have two questions:
1) If I just ignore these unrouted bits of air wires,
and go ahead and send the board out for manufacture,
might this come back to bite me later on?
2) Any way to avoid this, other than making my own
library version of every component?
And thanks in advance for the generous help on this
news group.
-lmc-
    On Sun, 15 Jun 2008 10:46:06 -0400, Larry Coyle wrote:
    I seem to be plagued with numerous tiny air wires on a board I'm trying
    to finish. These have the appearance of being "embedded" in the pads of
    SMD components. Ripping up and re-routing doesn't get rid of them.
    (But all of the copper trace connections seem to be OK.)
    I'm guessing that the library SMD parts I'm using for some reason are
    not on the grid (??!!), but I don't know any easy way to fix this. I've
    tried using both metric and English measure -- didn't help.
    1) If I just ignore these unrouted bits of air wires, and go ahead and
    send the board out for manufacture, might this come back to bite me
    later on?
    2) Any way to avoid this, other than making my own library version of
    every component?
    And thanks in advance for the generous help on this news group.
    -lmc
    If this is the problem I am thinking of, I believe I have had it too.
    Try this,
    show only the unrouted layer, and highlight all the airwires and delete
    them.  It won't delete the actual routes, (given your board and schematic
    are consistent) but it will delete all the 'fake' unroutes, and then give
    you and error "Can't backannotate this operation"
    That 'should' get rid of those unneeded airwires.
    But if that doesn't work, you can basically just try to re route the wire
    (without deleting it) with a wire of a thinner size than the one you use,
    just to make EAGLE work.
    Hope this helps
    Shawn
    On 2008/Jun/15 11:53 AM, in article g33dt7$nl6$1@cheetah.cadsoft.de, "Shawn
    later on?
    every component?
    -lmc
    Try this,
    This is a very bad idea.  You are deleting the "signals" that tell the board
    editor what gets connected to what.  I believe you lose your consistency
    when you do this (that is what the warning is telling you).
    The problem is that your trace doesn't end up at the exact coordinate of
    the center of the pad/smd.  So the delta is shown as an airwire.  The best
    way to get rid of this is to route from the pad outward.  The end of this
    route will be on your grid and thus be available as an exact match and thus
    no airwires.
    Cheers,
    James.
    ~  James Morrison  ~~~  Stratford Digital  ~
    ~  email:  sales@eagletoolkit.com          ~
    ~  fax:    888.701.8097                    ~
    ~  web:    http://www.eagletoolkit.com     ~
    ~  Online EAGLE Dealer for US and Canada   ~
    ~  EAGLE Design Experts                    ~
    ~  EAGLE Enterprise Toolkit                ~
    In article <g339ve$f45$1@cheetah.cadsoft.de>,
    get rid of them.
    After ripping the trace up, start routing at the offgrid pad and route
    to an ongrid position.
    This way, the new traces will be centered relative to the pads and you
    get rid of these short airwires.
    Making new packages in an own library won't help. There are many
    packages with metric pin spacing (even through-hole components, e.g. the
    2mm Metral connectors), and these will always be offgrid when you use a
    grid based on inches.
    So use the correct routing technique and you won't have problems.
    Best regards,
    Günther
