EAGLE User Support (English) Global Attributes 5.0
  • Subscribers 178 subscribers
  • Views 208 views
I'm trying to set up global attributes to be applied to every part in a
schematic (example: supplier , supplier part number, manufacture ...).
After setting them from the menu->edit-> global attributes they do not
appear when I select the attributes from each part (right click).
Does each part need to have all attributes defined in the library ?
I'm sure I'm missing something and somebody can help me out.
Cheers,
Mark Ovenden
  • Richard_H
    Richard_H over 17 years ago
    Mark Ovenden schrieb:
    Cheers,
    Mark Ovenden
    A global attribute is not a part-specific attribute.
    If you want to defin an attribute for a certain part, use the
    ATTRIBUTE command. Click onto the part and define attributes as
    needed.
    Richard Hammerl
