EAGLE User Support (English) DesignLink XML elements
  • Subscribers 178 subscribers
  • Views 254 views
Former Member over 15 years ago
What's the best way to determine what fields are available in the DesignLink return results?
    0 Former Member over 15 years ago
    If you look into the DesignLink ULP you will see there's an array, Products[]. This array contains all the search results. So, basically wherever you see an xmltext( ) function or an xmlelement ( ) function in the code, which are associated with the Products[], those are the fields which are displayed finally from the search results.
    I'm not sure if I have answered your question....??
    Best Regards,
    Jaya
    0 Former Member over 15 years ago in reply to Former Member
    Matt Collinge wrote on Thu, 24 June 2010 23:29
    It was your own question!
