EAGLE User Support (English) Detailed Command syntax for COPY w rotation option
  • Subscribers 178 subscribers
  • Views 254 views
I cannot find complete command syntax for a COPY command in a text script.
I want to copy the last selected group and apply an arbitrary rotation to it
at the same time.
All the literature I find alludes that it can be done and to follow the same
sytax as for the MOVE command, but, alas, I cannot find MOVE detailed syntax
either.
so far, all I have is:
    COPY (C> 0 0) (0 0); # copies last group using origin as reference point
and then places copy back on origin.
but this is only a normal copy, but I want to add an arbitrary rotation of
"n" degress when it is placed.
By the way, is there a good textual command syntax for all the commands
anywhere which includes all options?
thanks,
Dan
W3QDO
  • Richard_H
    Richard_H over 17 years ago
    at the same time.
    either.
    thanks,
    Dan
    W3QDO
    Simply do a
       ROTATE Rn (>0 0);
    after the COPY command.
    BTW: The C inside the parenthesis is not necessary.
    Richard Hammerl
    autodeskguest over 17 years ago in reply to Richard_H
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:g3njmc$a3q$1@cheetah.cadsoft.de...
    script.
    it at the same time.
    same sytax as for the MOVE command, but, alas, I cannot find MOVE
    detailed syntax either.
    point and then places copy back on origin.
    of "n" degress when it is placed.
    thanks,
    Dan
    W3QDO
    Simply do a
      ROTATE Rn (>0 0);
    Richard Hammerl
    Richard-
    Does the lack of a reference mean that there  is no "good textual command
    syntax for all the commands  anywhere "?
    JA
