EAGLE User Support (English) Upgrading Eagle
  • Replies 27 replies
  • Subscribers 189 subscribers
  • Views 2441 views
Upgrading Eagle
Hi
I have tried out the Eagle Freemium with great success, and am now deciding whether I should purchase the Standard or Pro version.  Can someone tell me whether if I purchase the Standard version and find in the future I need the Pro for a larger board layout whether I can upgrade or would I need to purchase the entire Pro version again?
Sorry if this question has been asked before, but I could not find it!
James
    0 e14 Contributor over 15 years ago in reply to e14 Contributor
    Oliver Betz wrote on Fri, 08 October 2010 02:29
    this has been discussed in the past.
    It has been discussed, but my points were never really addressed.  It seems
    some don't want it because they don't want it, but real technical reasons
    for that are elusive.
    Also, claiming that I "don't understand the core problems", but then
    refusing to discuss the issue is rather two-faced.
    Olin Lathrop wrote:
    >> Besides this, you demonstrated again that you don't understand the
    >> core problems, IOW the technical content of your posting was as wrong
    >> as in earlier threads. It doesn't get right by repeating it.
    >Then explain what you think is wrong with my argument.  Again, I see no
    this has been discussed in the past. Unless you bring up new
    information in the appropriate group image, I will not comment it
    further.
    Another prerequisite is that one of the "doers" (e.g. Farnell or
    contractor) takes part in the discussion.
    Oliver
    Oliver Betz wrote on Thu, 07 October 2010 12:37
    reason web forums should degrade the experience for anyone.  In fact, some
    things will get better if implemented as I suggest, such as attachment
    handling.  Currently attaching a large file is prohibited for good reason,
    since that file would be replicated to all NNTP subscribers.  If the
    original post went to a central server, it could put the attached file in
    one place and replace it with a easily clickable link in all the replicated
    NNTP messages.  If the attachement is a image, it could be displayed in
    line in the web forum, or perhaps a downsized version of it if the image is
    too big.  This is just one example of how it gets better for everyone, NNTP
    users included.
    Quote:
    te only problem is that we still don't have such a thing as a
    "properly implemented NNTP gateway".
    Right.  We're talking about how things should be, not necessarily how they
    are.  The current system has problems, but none of those are inherent to
    web forums to NNTP gateways.
    Olin Lathrop wrote four days ago:
    "Let's not get into that flame war again"
    and today:
    "NNTP bigot" ... "need to grow up"... "stuck in the 1990s" ... "look
    stupid".
    Maybe I don't understand exactly what a "flame war" is, but your
    wording is at least not supporting a fruitful discussion.
    >There is no technical reason a properly implemented NNTP gateway would
    >degrade the experience of the NNTP users, so there should be no objection
    JFTR: I do not vote against web access to this community. It just
    should be done correctly, keeping all current capabilities (e.g.
    threading and efficient access).
    Oliver
    0 e14 Contributor over 15 years ago in reply to kcadsoft
    Klaus Schmidinger wrote on Tue, 05 October 2010 05:37
    I have forwarded your message to the relevant people at Farnell.
    I note you only forwarded those comments that support your particular view
    of this issue.  It's not fair to let Farnell think everyone is a NNTP bigot
    regardless of the issues.
    The right solution is to create a decent web forum and make it the
    "official" place, then add gateways to and from NNTP.  Much of the problem
    comes from the fact that more meta-information can be described in a web
    post than in a NNTP post.  Obviously the best place to keep the database
    and consider the "official" place is where the most information can be
    preserved.
    on that front.  The only objections to this have been purely psychological.
    The NNTP users somehow feel threatened by this, although it's not clear
    why.  There also seems to be some attitude like "If I don't want it, nobody
    else should", with the intention of enforcing that somehow.  They need to
    grow up instead.
    If Farnell doesn't want to be seen stuck in the 1990s, then they need to
    provide a good web forum interface.  Sticking to NNTP as the main mechanism
    with web forums stuck on like afterthoughts is making them look stupid.
    Again there is no reason that a good NNTP gateway need to take anything
    away from those users that prefer NNTP, so there is little to loose by
    doing this.
    Please pass this on to the relevant people at Farnell too.
  • kcadsoft
    0 kcadsoft over 15 years ago in reply to e14 Contributor
    On 10/05/10 09:16, Oliver Betz wrote:
    since Farnell demonstrated that they were not able to create a
    suitable gateway to their forum software, couldn't they try now to
    offer an online access (web client) to the newsgroups?
    Starting points:
    http://amrhein.eu/newsportal
    http://amrhein.eu/newsportal/links
    http://www.newsoffice.de/
    Most important is to hire a qualified programmer!
    Oliver
    Klaus Schmidinger
    Pleidolfweg 15                          Email:   kls@cadsoft.de
  • kcadsoft
    On 10/04/10 21:17, Warren Brayshaw wrote:
    Right now I see two factions in Farnell that cannot or won't work together
    to fix a very fixable problem.
    I feel the onus is on you to do further work with that Farnell division to
    correct the issues that are certainly hurting your customer satisfaction
    ratings.
    Klaus Schmidinger
    Klaus Schmidinger wrote:
    >However, that would mean our support staff would have to
    >read all three of these places (two of them being web-frontends,
    >which, as we both know, is a nightmare to handle).
    >They would most likely end up answering the same questions
    >in all three places.
    >That's why, when Farnell wanted to have an EAGLE support forum,
    >we insisted on it being a mirror of our news groups. That way
    strictly speaking, a gateway (working in both directions).
    Starting points:
    Oliver
    Joern Paschedag wrote:
    All this could be stopped if the link connections between eaglecentral,
    farnell and cadsoft would be cut off..............
    Klaus Schmidinger replied
    I wish we could image
    our support staff has one central place to handle support
    requests, and the EAGLE community doesn't get segmented.
    Klaus Schmidinger
    Klaus
    Currently if a request from Element14 has an attachment, you have to go to
    the web interface to get it.
    If you wish to contact the poster directly you cannot from the newsgroup.
    That isn't "one central place".
    Farnell would, no doubt, like to be seen as a corporation that embraces
    quality in all that it does but this channel shows that this is not the
    case. Heads should roll and maybe some have because it appears that nobody
    is working to fix the issues.
    Personally, I don't assist any request that comes to the newsgroup from
    Element14. Perhaps others are reacting similarly.  If our contributions save
    CadSoft support staff time then Element14 is causing you more work.
    ratings.
    Warren
  • kcadsoft
    I am in the cadsoft newsgroup and I am in a lot of forums as well.
    So, why should there be a problem to go to the other locations separately?
    This half working links produce nothing more than a lot of
    misunderstandings which causes trouble and flames.
    So plase stop  that.
    Klaus Schmidinger
