EAGLE User Support (English) Upgrading Eagle
  • Replies 27 replies
  • Subscribers 189 subscribers
  • Views 2454 views
Upgrading Eagle
Hi
I have tried out the Eagle Freemium with great success, and am now deciding whether I should purchase the Standard or Pro version.  Can someone tell me whether if I purchase the Standard version and find in the future I need the Pro for a larger board layout whether I can upgrade or would I need to purchase the entire Pro version again?
Sorry if this question has been asked before, but I could not find it!
James
  • Richard_H
    0 Richard_H over 15 years ago in reply to e14 Contributor
    Am 29.09.2010 15:54, schrieb Tilmann Reh:
    Richard Hammerl schrieb:
    >> The original question is alread answered.
    >> As Jim Littlefield wrote in his message:
    >>>> From: Jim Littlefield <jameslittlefield@verizon.net>
    >>>> Newsgroups: eagle.support.eng
    >>>> Subject: Re: Upgrading Eagle
    >>>> Date: Sun, 26 Sep 2010 06:54:44 -0400
    >>>> Whenever I have upgraded (windows/linux vesions) the new Eagle
    >>>> version has installed in its own new directory leaving the
    >>>> older versions intact.   If you have created your own part
    >>>> libraries or modified any of the ones that come with Eagle
    >>>> you may have to selectively copy the revised lib files and/or
    >>>> modify the search path for libraries.
    I'm afraid you are referencing the wrong message.
    The OP of this thread is visible only in the element-14 forum - this is
    one more example of how extremely poor these interfaces work. image
    Here's the OP (quoted), posted by a James Cooper on 27.09.10:
    It's boring that those forums keep mangling the newsgroup data. If they
    can't correctly deal with them, they'd better stop accessing the
    newsgroups at all...
    Tilmann
    Hi Tilman,
    thank you for clarifying things.
    I basically don't use element-14 for the CadSoft nntp groups.
    So I referred to the wrong message which has the same subject and
    was posted some days ago in this group.
    I was not aware that messages posted via element14 can get lost and
    are not visible in the original CadSoft groups. I hope somebody of
    the responsible persons reads this and will react on it.
    Richard Hammerl
    0 e14 Contributor over 15 years ago in reply to Richard_H
    Tilmann
    I knew the first point but i discover the second.
    Thanks Richard.
  • Richard_H
    Am 29.09.2010 15:06, schrieb nicolas badel:
    I think that you can't update the standart version to obtain a pro edition.
    i afraid that the only solution is to buy it again.
    Nicolas
    >> Jim
    BTW:
    1.
    You don't have to buy this version again. I suppose Dewdy bought
    a license for version 5 (he works with 5.2.0), so he can use all
    the following releases 5.x.x without extra costs.
    2.
    It is possible to buy an upgrade from standard edition to professional
    edition. You simply pay the difference of the two prices.
    Tillman's answer is correct
    Richard Hammerl
    0 e14 Contributor over 15 years ago in reply to e14 Contributor
    What makes you think so?
    AFAIK, it has always been possible to upgrade to "larger" versions.
    Tilmann
    Nicolas
    I think here: http://www.cadsoft.de/order.htm
