EAGLE User Support (English) Gerber import into eagle
  • Subscribers 184 subscribers
  • Views 1021 views
Former Member over 15 years ago
I am trying to import gerbers that were created in CADENCE into EAGLE.
I managed to find a tool EAGLE power script tools which allows you to convert the top and bottom layers of the board into a script file which is then openable in EAGLE.
But these only convert one layer at a time. How i then merge these two layers into one file?
    0 Former Member over 15 years ago
    you could use EAGLE's cut and paste commands to combine them. Not sure
    how you will align them though if they are skewed.
  • Richard_H
    0 Richard_H over 15 years ago in reply to Former Member
    Am 05.11.2010 21:04, schrieb Gary Gofstein:
    Why not simply run both script in the same board?
    Richard Hammerl
