EAGLE User Support (English) Eagle 5.0.0 crashes randomly in WinXP
  • Replies 21 replies
  • Subscribers 190 subscribers
  • Views 1857 views
Eagle 5.0.0 crashes randomly. It has done it over ten times. I've
re-installed and it still occures. Appears to be no pattern. Crashes when I
am not using it, browsing in library, editing a circuit. It appears to be
entirely random
AppName: eagle.exe  AppVer: 0.0.0.0  ModName: unknown
ModVer: 0.0.0.0  Offset: 100011f5
Any help greatly appreciated.
Roger
  • MontanaEE
    MontanaEE over 18 years ago in reply to MontanaEE
    Well, ran the memory tests, No anomalies, so that's good.  I was kind of
    hoping that would be it.  Is anyone else having an issue like this with 5.1?
    Thanks for any inputs.
    Stephen
    "Baron" <baron.nospam@linuxmaniac.nospam.net> wrote in message
    news:g5djhc$o8m$1@cheetah.cadsoft.de...
    Stephen wrote:
    Just crashed again.  Tried to add a USB connector to the pcb.  Got an
    error saying "No back annotation will be performed, please add this
    from
    schematics." or something similar.  This is weird because I was in the
    schematic when I hit the Add Parts icon.  Then Eagle completely locked
    up, and I get a Windows error again.
    What type of information do you need from us to help you resolve this.
    We have to get this fixed, I've lost so much time with this issue with
    losing
    15-20 minutes worth of work each time.  Please advise.
    Stephen Doll
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:g54e1v$gbp$1@cheetah.cadsoft.de...
    On 07/09/08 23:42, T.Strothmann wrote:
    "Stephen" <stdoll77@centurytel.net> schrieb im Newsbeitrag
    news:g51ira$jfs$1@cheetah.cadsoft.de...
    Eagle 5.1.0 Crashes Randomly with XP.  This has happenned about 10
    to 15
    times in the last week.  I am running Eagle 5.1 on WinXp and for no
    apparent reason Eagle crashes and dumps me out to Windows.  No
    chance to
    save anything, just dumps out.  Cumulatively, I've lost several
    hours
    worth of work due to this.  Please advise.....
    Stephen Doll
    KLS: wasn't there this weird report about memory access violations
    etc.? What about it? Is this to be taken seriously, maybe?
    We have found three problems that might cause crashes:
      - Fixed a crash when changing the grid color while a library is
      open
        without having edited a particular package, symbol or device set,
        yet, and the grid is actually displayed.
      - Fixed a crash when entering a curve parameter (like "@+20") in a
    command
        that works with wires, without an actual wire attached to the
        cursor.
      - Fixed a possible data corruption after changing the coordinates
      of an
        object or the layer of a wire in the properties dialog, in case
        this resulted in a wire optimization.
    These will be fixed in version 5.1.1.
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
    Sounds awfully hardware related.  Get a copy of "Memtest @ memtest.org"
    and run it overnight.  Just rules out memory errors !
    HTH
    Best Regards:
                        Baron.
    autodeskguest over 18 years ago in reply to MontanaEE
    from
    losing
    Stephen Doll
    to 15
    chance to
    hours
    Stephen Doll
      open
    command
        cursor.
      of an
    Klaus Schmidinger
    HTH
    Best Regards:
                         Baron.
  • MontanaEE
    Just crashed again.  Tried to add a USB connector to the pcb.  Got an error
    saying "No back annotation will be performed, please add this from
    schematic when I hit the Add Parts icon.  Then Eagle completely locked up,
    What type of information do you need from us to help you resolve this. We
    have to get this fixed, I've lost so much time with this issue with losing
    Stephen Doll
    Eagle 5.1.0 Crashes Randomly with XP.  This has happenned about 10 to 15
    apparent reason Eagle crashes and dumps me out to Windows.  No chance to
    save anything, just dumps out.  Cumulatively, I've lost several hours
    Stephen Doll
    KLS: wasn't there this weird report about memory access violations etc.?
      - Fixed a crash when changing the grid color while a library is open
        without having edited a particular package, symbol or device set, yet,
    command
        that works with wires, without an actual wire attached to the cursor.
      - Fixed a possible data corruption after changing the coordinates of an
        object or the layer of a wire in the properties dialog, in case this
    Klaus Schmidinger
  • kcadsoft
    kcadsoft over 18 years ago in reply to MontanaEE
    Stephen Doll
       - Fixed a crash when entering a curve parameter (like "@+20") in a command
    Klaus Schmidinger
  • esilviu
    esilviu over 18 years ago
    latest eagle crashed many times when running from USB stick
    "roger jennings" <skateinthedraft@yahoo.com> wrote in message
    news:g3vd7d$p3q$1@cheetah.cadsoft.de...
    I am not using it, browsing in library, editing a circuit. It appears to
    be entirely random
    Roger
    Stephen Doll
    T.
  • MontanaEE
    times in the last week.  I am running Eagle 5.1 on WinXp and for no apparent
    reason Eagle crashes and dumps me out to Windows.  No chance to save
    anything, just dumps out.  Cumulatively, I've lost several hours worth of
    Stephen Doll
    "Richard Hammerl" <ric@cadsoft.de> wrote in message
    news:g4a5qr$m4k$1@cheetah.cadsoft.de...
    Could you please try our current beta 5.0.3? There is one
    issue concerning crashes solved.
    I have downloaded and copied the beta 5.0.3 files over the 5.0.0 install.
    It still crashes, but not as quickly or as often.
    Any suggestions on how I can help narrow down the cause of crashes?
    The first step is to try to get out how to reproduce the crash.
    Do you have a certain procedure that provokes it?
    I was attempting to find a method for consistent crashing - its very random.
    Previously I had never actually closed Eagle properly, always restarting it
    from a crash. Opening up some libraries, it looked like it was doing some
    updating or converting. I then closed properly and restarted, it has not
    crashed since (after creating a library, creating and copy
    components/devices, create a circuit and board).
    It appears stable now.
    Perhaps the work around was to browse libraries, close normally (rather than
    wait for crash), and re-open.
    Thank you,
    Roger
  • Richard_H
    Richard_H over 18 years ago
    Roger
    Richard Hammerl
    Roger
