EAGLE User Support (English) Eagle 5.0.0 crashes randomly in WinXP
  • Replies 21 replies
  • Subscribers 190 subscribers
  • Views 1839 views
Eagle 5.0.0 crashes randomly. It has done it over ten times. I've
re-installed and it still occures. Appears to be no pattern. Crashes when I
am not using it, browsing in library, editing a circuit. It appears to be
entirely random
AppName: eagle.exe  AppVer: 0.0.0.0  ModName: unknown
ModVer: 0.0.0.0  Offset: 100011f5
Any help greatly appreciated.
Roger
  • kcadsoft
    kcadsoft over 18 years ago in reply to MontanaEE
    On 08/27/08 18:52, Stephen wrote:
    Klaus,
    It always happens when I'm creating a new part in a library.  Most of the
    time when I put in the new name of the part in the dialog box.  It either
    crashes there when I hit enter, or it waits until I hit Yes in the following
    box.  I'll pay closer attention next time.
    I tested creating a new part in a library, but nothing bad happened.
    Does it happen only with one particular library, or with any library?
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
  • MontanaEE
    MontanaEE over 18 years ago in reply to MontanaEE
    Klaus,
    Stephen
    "Klaus Schmidinger" <Klaus.Schmidinger@cadsoft.de> wrote in message
    news:g930l5$177$1@cheetah.cadsoft.de...
    On 08/27/08 07:07, Stephen wrote:
    Bummer!!
    I downloaded and installed 5.2 after having no issues with the Beta 5.1.3
    version.  I now get the following error.
    Application Error: Eagle: Eagle.exe
    The instruction at 0x77c2b9b5 referenced memory at "0x00000004".  The
    memory cannot be written.
    I run Memtest all night with no memory problems.  I realize that is
    somewhat foolish as I did not have this happen with the Beta 5.1.3 so it
    is obviously a version issue, but I wanted to be sure.
    Does this happen just out of the blue, or when you perform a particular
    action?
    Klaus Schmidinger
  • kcadsoft
    Bummer!!
    The instruction at 0x77c2b9b5 referenced memory at "0x00000004".  The memory
    cannot be written.
    I run Memtest all night with no memory problems.  I realize that is somewhat
    foolish as I did not have this happen with the Beta 5.1.3 so it is obviously
    action?
    Klaus Schmidinger
  • MontanaEE
    Bummer!!
    cannot be written.
    Stephen
    "Stephen" <stdoll77@centurytel.net> wrote in message
    news:g7j70u$chc$1@cheetah.cadsoft.de...
    Thanks all,
    New update.  I have been running with Beta version 5.1.3 for several days
    with no crashes.  My only concern right now is that I am using a Beta
    version to fiinish my production boards which I need to order on Monday.
    I have no choice though unless a release comes out before then, my
    customers don't much care why a project is behind, just that it's late.
    Thanks for all of the suggestions, even though this had nothing to do with
    my hardware, it's good to verify that end once and awhile anyway.
    Stephen
    "Chetan Bhargava" <please@use-newsgroup.com> wrote in message
    news:g78vdi$tne$1@cheetah.cadsoft.de...
    Sometimes BIOS updates fix a lot of things. Check if you have the latest
    BIOS.
    Recently one of my systems (using Asus P5N-D) was acting up so I
    suspected the memory and replaced with crucial ballistix. Problem
    remained and crashes kept coming back. Thought that the motherboard is
    bad. BIOS update fixed it and it is now stable.
    -Chetan
    Stephen wrote:
    Okay,
    I have confirmed the this is not a problem with my hardware.  I have ran
    every memory test, disk access, dxdiag, video, bit test etc. I can find
    and my hardware is stellar.  No issues.  This is the only program that
    consistently crashes.  It always seems to be when I am working with the
    libraries.  I had no issues, or crashes for that matter with Version 4.
    This has effectively stopped both projects I have in development.  It's
    really difficult to build a board with no parts.  I see from several
    emails from different users that crashes during library usage is the
    common point, that should be a place to start with debug I think.
    Please advise.
  • MontanaEE
    MontanaEE over 18 years ago in reply to autodeskguest
    Thanks all,
    version to fiinish my production boards which I need to order on Monday.  I
    have no choice though unless a release comes out before then, my customers
    Stephen
    BIOS.
    Recently one of my systems (using Asus P5N-D) was acting up so I suspected
    the memory and replaced with crucial ballistix. Problem remained and
    crashes kept coming back. Thought that the motherboard is bad. BIOS update
    -Chetan
    Stephen wrote:
    Okay,
    common point, that should be a place to start with debug I think.  Please
    advise.
    BIOS.
    -Chetan
    Stephen wrote:
    Okay,
    every memory test, disk access, dxdiag, video, bit test etc. I can find and
    really difficult to build a board with no parts.  I see from several emails
    from different users that crashes during library usage is the common point,
    that should be a place to start with debug I think.  Please advise.
  • Richard_H
    Richard_H over 18 years ago
    Stephen schrieb:
    Okay,
    Did you already try the current beta version as Mr. Schmidinger
    suggested in his answer before?
    Richard Hammerl
  • MontanaEE
    MontanaEE over 18 years ago in reply to esilviu
    Okay,
    Stephen
    "eSilviu" <Silviu.Epure@ugal.ro> wrote in message
    news:g54bag$8sm$1@cheetah.cadsoft.de...
    latest eagle crashed many times when running from USB stick
    "roger jennings" <skateinthedraft@yahoo.com> wrote in message
    news:g3vd7d$p3q$1@cheetah.cadsoft.de...
    I am not using it, browsing in library, editing a circuit. It appears to
    be entirely random
    Roger
    autodeskguest over 18 years ago in reply to MontanaEE
    Stephen wrote:
    Well, ran the memory tests, No anomalies, so that's good.  I was kind
    of hoping that would be it.  Is anyone else having an issue like this
    with 5.1?
    Thanks for any inputs.
    Stephen
    "Baron" <baron.nospam@linuxmaniac.nospam.net> wrote in message
    news:g5djhc$o8m$1@cheetah.cadsoft.de...
    Stephen wrote:
    Just crashed again.  Tried to add a USB connector to the pcb.  Got
    an error saying "No back annotation will be performed, please add
    this from
    schematics." or something similar.  This is weird because I was in
    the
    schematic when I hit the Add Parts icon.  Then Eagle completely
    locked up, and I get a Windows error again.
    Sounds awfully hardware related.  Get a copy of "Memtest @
    memtest.org" and run it overnight.  Just rules out memory errors !
    HTH
    Best Regards:
                        Baron.
    Well at least that rules out the most common cause of program
    malfunctions, bad memory/ram !
    Does this kind of problem happen with any other applications ?
    Particularly if recently installed.
    Assuming that it does then other possibilities are the PSU and heat.
    These would be my next things to check.
    Best Regards:
                         Baron.
  • kcadsoft
    On 07/13/08 03:54, Stephen wrote:
    Just crashed again.  Tried to add a USB connector to the pcb.  Got an error
    saying "No back annotation will be performed, please add this from
    schematics." or something similar.  This is weird because I was in the
    schematic when I hit the Add Parts icon.  Then Eagle completely locked up,
    What type of information do you need from us to help you resolve this. We
    have to get this fixed, I've lost so much time with this issue with losing
    15-20 minutes worth of work each time.  Please advise.
    Please test whether this problem still persists with the latest
    beta version 5.1.1 (see http://www.cadsoft.de/betatest.htm).
    Klaus Schmidinger
