EAGLE User Support (English) Moving Pins on Microprocessor
  • Subscribers 177 subscribers
  • Views 245 views
I have created a 'generic' symbol for a microcontroller in a library.  The
symbol has all of the port pins grouped logically, power and ground
connections, crystal... etc
When I bring the part into a design, I like to move the pins around the
microcontroller to match up with the interface circuitry easily.
Is there a way to move the pins on the 'local copy' of the symbol, or must I
edit the library copy and update the symbol in the schematic?
Greg
    If you really want different appearance of the symbols, you need to
    create different symbols (and devices!) in the library.
    Since you would end up with a unmaintainable library mess, I strongly
    suggest to use "fixed" symbols and draw the schematics accordingly.
    I most often draw only net stubs (with labels) at the controller, and
    reuse these nets elsewhere in the circuit. This has the advantage that
    it's easy to swap port pins (where allowed) to match the board layout
    during routing. Using a bus might also help in several cases.
    Tilmann
    On Thu, 26 Jun 2008 gregrycm wrote saying :
    The only sensible way to do this is to make all the individual pins
    separate, rather as a number of the connector components are. If all the
    pins are set to "always" add, then placing the component will place all
    the pins in the order they appear in the library device. This would give
    the appearance of your current generic symbol. Then you can move the
    pins around on the schematic as you like.
    That said, I'd recommend against that level of partitioning. If the
    micro in question has more than 40 port pins you may want to create each
    port (group of 8) as a separate entity. Any further just gets horribly
    messy.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of this | Windows NT crashed.
    message are purely   | I am the Blue Screen of Death.
    my opinion. Don't    | No one hears your screams.
    believe a word.      |
