EAGLE User Support (English) DRC errors
  • Subscribers 185 subscribers
  • Views 337 views
DRC errors
SMD111
SMD111 over 15 years ago
I created a model for Tyco connector 6-104078-3, which has 68 round pads with 0.05” spacing, 0.032” diameter, 0.023” drills.
The DRC keeps giving me hundreds of “Clearance” errors. I have all clearance settings in DRC equal to 8 mil.
I do not understand this:
50 mil spacing minus 32 mil pad diameter = 18 mil clearance, more than twice the minimal setting, but I still get these errors in DRC.
Please advice.
    0 Former Member over 15 years ago
    On Tue, 15 Feb 2011, SMD111 wrote to us saying :
    >Please advice.
    Most likely the diameter isn't 0.032" because that requires a "restring"
    of only 0.0045" which is less than your DRC settings. It's a very tight
    connector!
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
  • SMD111
    0 SMD111 over 15 years ago
    Thank you, Rob!
    I changed the pad size to 0.04" and that made restring become 0.0082 - just enough to satisfy the restring minimum in DRC, while still leaving 0.01" of clearance between the pads. A tight fit indeed! But I don't get a single error after running DRC now.
    Thus, in fact, it was a "Restring" error, not a "Clearance" one. Since the DRC settings window has tabs with both of these words, the error message with "Clearance" word is misleading and should be changed in future versions.
