EAGLE User Support (English) Eagle V5.11.0 can you explain how to get the attributes to be global?
  • Subscribers 177 subscribers
  • Views 148 views
Help info quote
"Global attributes Global attributes can be defined in boards and schematics by using '*' as the part name (which implies that this attribute applies to all parts)."
How does this work it seems the same 'ATTRIB' used on both the schematic and the boards needs to be setup in both global attribute lists under the edit menu.
It looks like global means global within either the schematic or within the board but not global across bot at the same time.
