EAGLE User Support (English) create custom shaped holes
  • Subscribers 187 subscribers
  • Views 601 views
  • holes
Hi all,
I am trying to create a custom hole shape for a rca jack's mounting pins (see attached datasheet) but I cant find how to do it anywhere...any help much appreciated.
Charles
imageRCA_through_hole.pdf
  • Richard_H
    0 Richard_H over 15 years ago
    Am 26.02.2011 06:56, schrieb charlestrep91:
    Hi all,
    Charles
    Hi Charles,
    non-circular holes usually will be milled in the production process
    and have to be drawn manually in EAGLE. The contour of the "hole"
    should be drawn with a very fine width (e.g. with the WIRE command)
    in a special layer. EAGLE uses layer 46, Milling, for this. Be sure
    to inform the board manufacturer that there are milling contours in
    this layer. In case you create manufacturing data by yourself, add
    one Gerber file that contains layer 46.
    Richard Hammerl
