EAGLE User Support (English) Import board outline from Solidworks to Eagle
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 2210 views
I'm trying to figure out if there is a way or script available to import into Eagle the outline of a board designed in Solidworks.  All I need is for the board's dimensions to be transfered to Eagle, preferably as dimension layer 20.  The current file extension that I've been given from Solidworks is .sldprt.  Does anyone have any suggestions or thoughts on how I might go about doing this?
Thanks!
  • aksispd
    0 aksispd over 8 years ago
    Eagle 5.8.2 has the import_dxf ulp and it works perfectly with dxf-s saved from solidworks with default settings. Watch out where the origin on the model is, you might have to shift things around with the origin parameters.
    0 e14 Contributor over 15 years ago in reply to Richard_H
    Thanks for the help everyone.
    I endedup downloading the demo version of the power tools and that worked just great.
    Thanks again,
    Dustin
  • Richard_H
    0 Richard_H over 15 years ago in reply to e14 Contributor
    Am 19.02.2011 02:24, schrieb Gary Gofstein:
    On 2/18/2011 4:54 PM, Dustin Lane wrote:
    >> James,
    >> I think you may have misinterpreted my question.  I don't want to
    >> export a board layout from Eagle, I in fact want to do the opposite.
    >> I want to import a board layout into eagel from Solidworks.  I have
    >> been able to get a dxf file from Solidworks, I just need to find some
    >> sort of script that will read it into Eagle for me.  Do you know of
    >> anything like that?
    >> Thanks.
    Go to the eagle downloads area on their website, there is a rudimentary
    ULP to import polygons in .dxf
    No idea how well it works, but probably get you most of the way there...
    As far as I know  eagle_pcb_power_tools.... by Falk Stricker can do.
    ==> ftp://ftp.cadsoft.de/eagle/userfiles/misc/
    Hope this helps.
    Richard Hammerl
    0 e14 Contributor over 15 years ago in reply to e14 Contributor
    James,
    I think you may have misinterpreted my question.  I don't want to export a board layout from Eagle, I in fact want to do the opposite.  I want to import a board layout into eagel from Solidworks.  I have been able to get a dxf file from Solidworks, I just need to find some sort of script that will read it into Eagle for me.  Do you know of anything like that?
    Thanks.
    James,
    Thanks.
    Element 14 User wrote on Thu, 17 February 2011 17:42
    Yes, what you want is to use the dxf.ulp to export data in DXF format.
    There are also a few other ULP's that do similar things in CadSoft's
    http://www.cadsoftusa.com/cgi-bin/download.pl?page=/home/cadsoft/html_public/download.htm.en&dir=eagle/userfiles/ulp
    at the website.  If I recall, there is one there that handles layer 0
    better which is an issue with some CAD programs.
    You can even export the traces and silk etc which can help a bit verifying
    fit, clearances etc -- though that all has to be done manually.  I've done
    exactly what you are doing so I know that it can be made to work.  It's not
    ideal but it's better than nothing.
    Good luck.
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    • EAGLE Enterprise Toolkit
    On 02/17/2011 05:42 PM, Dustin Lane wrote:
    Eagle has a DXF import ulp which I've never used it and can't provide
    any guidance on it.  So if you can get Slodiworks to export to that
    format, you may be in business.
    Enjoy,
        - Chuck
