EAGLE User Support (English) Changing default >NAME and >VALUE
  • Subscribers 178 subscribers
  • Views 639 views
I'm wondering if there's a script or something that will allow me to change
the text size of >NAME and >VALUE in an entire library.
Most of them are using 50 or 70 mil text size, I want to change it to 24 mil
but don't want to smash every component, is there a way to do this easily?
Cheers
//Greg.
    Former Member over 17 years ago
    try: change-text-in-lbr.ulp
    from the header:
    #usage "
    Change lib text sizes
    \n"
    This script loops through all packages in a library and changes
    the text size and ratio to new user specified values.
    r
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> wrote in message news:g4rd5b$if7$1@cheetah.cadsoft.de...
    from the header:
    #usage "<b>Change lib text sizes</b>\n"
          "<p>This script loops through all packages in a library and changes the text size and ratio to new user specified values.
    r
    Thankyou!
    Found it in the downloads section....
    It doesn't seem to work on the schematic though?
    I only get it to work on the board...
    But half the work is done with the script - thankyou again image
    //Greg
    autodeskguest over 17 years ago in reply to autodeskguest
    "Greg" <ash_4@gravitywell.org> wrote in message
    news:g4rkc5$2md$1@cheetah.cadsoft.de...
    from the header:
    r
    Thankyou!
    //Greg
    Greg,
    Here's how I do it (in schematic as well as board layout)
    - I use the "Select" tool to select all devices
    - next I use the "Smash" command with the right mouse button to smash all
    components simultaneously
    - select all components again
    - now use the Change>Size also with the richt mouse button to change the
    size of all names and values simultaneously.
    That way you don't have to change any library.
    There's a drawback however : if you added text to your schematic or board,
    this will be changed as well if it's within the selection
    BTW, 24 mil text size on a board? I don't think any PCB manufacturer is
    capable of screen printing text of that size. You'd better check with your
    board mfg first.
    Cheers,
    Robert
