EAGLE User Support (English) Eagle 4.16r1 - symbol NAME and VALUE do not appear on schematic
  • Subscribers 187 subscribers
  • Views 2053 views
  • eagle
  • sch
  • schematic
  • question
Hi All,
I'm trying to understand and document a design performed by another company (a long time ago, in a galaxy far, far away . . .)  I have Eagle 4.16 that was used to create the schematics and boards.  The original designers are long gone.
I can bring up the schematic without problem; however, in 9 instances the NAME and VALUE information does not show on the schematic.  The information is in the file because the names & values appear when I click on those buttons and then click on the respective part.  I've "poked around" in all the menus and tried different things to no avail.  I've read through the user's manual and tried to find some web posts, also with no avail.
I would appreciate any hints or advice to help me figure out how to repair this situation.
Nick . . .
    0 e14 Contributor over 15 years ago in reply to e14 Contributor
    Am 30.03.2011 20:33, schrieb Jorge Garcia:
    On 3/30/2011 2:03 PM, nb-man wrote:
    >> Hi All,
    >> information is in the file because the names& values appear when I
    >> Thanks,
    >> Nick . . .
    Hi Nick,
    I'm willing to bet that those instances are custom made components. What
    probably happened is that whoever made the library for those components
    forgot to include place holders for the NAME and VALUE parameters.
    I came in with version 5, so I'm not familiar if version 4.16r2 had the
    exp-project-lbr.ulp. This ULP extracts the libraries from the schematic
    and board files. You would then correct the offending part in the
    library. In my personal experience, this ULP works best when you allow
    it to create multiple libraries.
    Once the library has been corrected you can then use the Update in the
    schematic editor, and that should allow you to see the names and values
    of your components.
    Best Regards,
    Provided that all layers are turned on and you still can't see
    name/value then I'm with Jorge about custom libraries image
    However if you have exported the used libraries with the ulp and correct
    them, the "library update" wouldn't help you, because eagle is still
    updating the original used library which you have not changed.
    The easiest way is of course to correct the libraries if they still
    exist. Cut name/value from a good part and paste, paste, paste...
    Joern Paschedag
    Hi All,
    I can bring up the schematic without problem; however, in 9 instances the NAME and VALUE information does not show on the schematic.  The information is in the file because the names&  values appear when I click on those buttons and then click on the respective part.  I've "poked around" in all the menus and tried different things to no avail.  I've read through the user's manual and tried to find some web posts, also with no avail.
    Nick . . .
    Hi Nick,
    of your components.
    Best Regards,
