EAGLE User Support (English) Adding 2804 - Darlington Transistor Array
  • Subscribers 178 subscribers
  • Views 601 views
  • eagle
  • transistor
  • 2804
  • darlington
  • array
Hey everyone,
I am new to Eagle software and to schematic design in general, but I am having an issue trying to add a part from the transistor-array.lbr, more specifically, the ULN-2804.
I try to add it and I get an error saying that it has unconnected pins. I go into the Library Editor and the Connect screen. I can see the extra pin G$1.19, however I cannot figure out how to remove it. Can anyone assist? Since I am new to this program, the more detail the better.
Thank you!
Joe
    0 Former Member over 14 years ago
    On Sun, 10 Apr 2011, firebirdta84 wrote to us saying :
    The version of this device in the uln-udn.lbr works for me. I suggest
    you try that one.
    You may want to try fixing the faulty one by editing the library,
    because creating and editing library parts is a skill you will find
    invaluable very soon, but for now I'd use the one that's correct.
    Rob Pearce                       http://www.bdt-home.demon.co.uk
    The contents of     | All power corrupts, but we need electricity.
    this message are    |
    purely my opinion.  |
    Don't believe a     |
    word.               |
    0 Former Member over 14 years ago in reply to Former Member
    Thank you so much! I must have missed that library during my initial search.
    Joe
    Am 10.04.2011 15:31, schrieb firebirdta84:
    Hey everyone,
    Thank you!
    Joe
    Wellcome on board image
    The library files in the download section are user files. Some of them
    have errors and besides nobody garantees for error free libraries anyway.
    Usually eagle users report errors of Cadsoft files, so they can be
    corrected on the next update. That does not go for user files.
    In case of the mentioned library the pin 19 is on top of pin 4 in the
    symbol. You can find it by moving that pin away from the original
    position in the library. Then you can remove it.
    You could have found the device in the eagle uln-udn.lbr by the way.
    But if you prefer the more graphic symbol of the user library then you
    should also correct the (electrical) direction of the pins which here
    are all wrong I/Os. Correct would be INPUTS and OC (open collectors).
    You should correct that library for your own skill because library
    editing makes the other 50% of layouting. Aaaaand finally you should not
    touch the eagle libraries. Create your own libraries because all of your
    work will be lost if you do an eagle update and the libraries are
    overwritten image
    Joern Paschedag
