EAGLE User Support (English) Copying the layout of identical channels
  • Replies 7 replies
  • Subscribers 180 subscribers
  • Views 743 views
I am designing an amplifier board with four identical channels. Is there a
way to copy the layout of the first channel so I don't have to repeat the
whole parts placement process four times?
Thank you.
Jeff
    As often been discussed and explained here...
    Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
    Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
    Tel. 06151 162516 -
    Fax. 06151 164321 -
    Uwe,
    I have downloaded and searched all messages in this user group and have not
    found the answer to this question. Perhaps I am using the wrong search
    terms. If you can point me to the correct message I would appreciate it.
    Thank you,
    Jeff
    "Uwe Bonnes" <bon@elektron.ikp.physik.tu-darmstadt.de> wrote in message
    news:g54k1g$fsi$1@lnx107.hrz.tu-darmstadt.de...
    a
    --------- Tel. 06151 162516 -------- Fax. 06151 164321 ----------
    Former Member over 17 years ago
    try panelize.ulp, read the header for instructions
    r
    Jeffrey L Rothman wrote:
    Uwe,
    Thank you,
    Jeff
    a
    From 4/15/2007
    Subject: duplicating common sections without re-layout?
    You may need to find a better newsreader then outlook to get all of the
    posts.
    Paul R.
    COME ON everyone... give him a break.  Why roast someone because he tried to
    find 'copy' instead of 'duplicate'.  There's the same problem with the *%&$#
    manual.  Unless you happen to guess the correct term, which is frequently
    not what we use in the US, it also  is useless.   (cut for copy, for
    example)
    Also, I thought this was the eagle "support" forum.
    Wasn't it as easy to give him the date as it was to say "get a better
    reader".  Much as I dislike defending MS, I find nothing wrong with using
    OE.  I have all the posts to the forum since I joined in 2004.  It doesn't
    make any difference what reader you use, they can only search for what you
    enter.
    Jack Adams
    Original Message -
    Newsgroups: eagle.support.eng
    Sent: Monday, April 16, 2007 8:24 AM
    Subject: Re: duplicating common sections without re-layout?
    Hi, I'm a little surprised but delighted that it works!  I was playing
    with a ulp I found on the eagle website, but it wasn't working so well.
    Thanks!!
    tyler
    Thank you.
    Jeff
    From a post in January this year
    > As I posted elsewhere in this thread, here's my complete guide on how to
    > duplicate an area of a layout and retain back/forth association to the
    > schematic.
    > Some others have reported that this doesn't work.  That is, they run the ERC
    > and see a list of errors that includes nets that don't simply have the 1 or
    > 2 or 3 appended to the end.  In a recent application of the procedure below,
    > I ran into this same error.  There were two things that caused this error:
    > 1. I pasted a section of my schematic so that it fell outside the valid
    > screen area.  It pasted visually, but I wasn't able to move anything again.
    > I'd get an error about trying to work outside the valid range.  To get
    > around this, I set my grid at 1.00 inch and made it visible.  Then I zoomed
    > all the way out and could see the valid paste area.  I made sure my pastes
    > all fell inside this window.
    > 2. I had created (and was trying to copy) nets in my layout that were not in
    > my schematic.  Specifically, I have a ground ring around the perimeter of my
    > board that I drew in at the layout level.  I was planning on connecting it
    > to PE (and my schematic) later.  This made the schematic and layout not
    > technically synchronized, even though the ERC reported no inconstancies.  To
    > get around this, I renamed the nets to what they were going to ultimately
    > end up as: PE.  I also tried naming them GND just to temporarily tie them to
    > a know net.  Both of these solutions worked.
    > The Procedure:
    > Sometimes circuit boards will have duplicate sections of schematic that you
    > want to layout identically.  You could do this by laying out each section
    > separately, but for large or complex layouts this would be very time
    > consuming.  Eagle does not have a function that allows you to directly
    > duplicate your layouts, so you have to use this workaround:
    > 1. Create the schematic for the section you want to duplicate.  You can have
    > additional schematic done at that time too if you like.
    > 2. Create the layout for that section.  You can have additional layout done
    > at that time if you like.
    2 (a) Often a critical step is to run a renumber ULP so that you close any
    holes in the component name sequence that may have arisen during editing.
    > 3. Close the layout so that you only have the schematic open.
    > 4. Use the window selection tool to surround the section of schematic you
    > want to duplicate in the layout.
    > 5. Use the scissors tool to copy the selection to the buffer.
    > 6. Use the dropdown EDIT: PASTE to finish the copy operation.
    > 7. Save the schematic and close it.
    > 8. Open the layout. Click OK to acknowledge the warning about the schematic
    > and board not being consistent. Close the schematic that opened when you
    > opened the layout so that you only have the layout open.
    > 9. Do the same window select, scissors, paste operation on the layout.  YOU
    > MUST COPY EXACTLY THE SAME ITEMS AS YOU DID IN THE SCHEMATIC.  THIS INCLUDES
    > COMPONENTS AND NETS.
    > 10. Save the layout and open the schematic.  You should have both the
    > schematic and layout open at this point.
    > 11. In the layout, run ERC and you'll get a long list of nets that don't
    > match.  Don't worry: you only have to fix each net once.  This is usually
    > only 5 or 6 nets to fix the whole list.
    > 12. The original section of layout will have nets named GND.  The new
    > section will have them named GND1.  The original section of the schematic
    > will have the nets named GND.  The new section will also have them named
    > GND.  The task here is to rename the net GND1 to GND in the layout.
    > 13. Type "show GND1" in the command line.  This will highlight GND1.
    > 14. Use the name tool (R2 Icon) to change the name GND1 to GND.  If
    > prompted, the rename applies to all nets.
    > 15. If you run ERC again, you'll find that all of the GND/GND1 errors are
    > gone.  Redo this renaming process a few more times for the remaining name1
    > nets and you're done.
    > Additional note: If you don't have any airwires for the net you're trying to
    > rename then you'll have to create one using the line tool and the name tool:
    > Create a line.  Rename that line using the R2 tool to the net name you need
    > to rename (e.g. GND1).  This will connect the line to the pad that was
    > previously un-airwired.  Now you can rename the airwire or line to the right
    > name (e.g. GND) to fix that net.
    cheers
    David
  • Morosh
    Morosh over 17 years ago
    "Jeffrey L Rothman" <jrothman@acsalaska.net> wrote in message
    news:g549oh$3sk$1@cheetah.cadsoft.de...
    Thank you.
    Jeff
    Hello:
    Try "duplicating_v41.zip" in ulp dowload area (for version 4).
    Maurice
