Hi there...
Can a pad have different sizes on the Top and Bottom layers, i.e. large
on Bottom layer and small/non-existent on Top layer? If so how is it
done? This is for one component only, not global on the pcb...
Thanks, regards
Lance
Hi there...
Thanks, regards
Lance
Lance Johnstone schrieb:
Hi there...
Thanks, regards
Lance
There is only a global parameter for this: Design Rules, Restring.
To have it different for a single component, you could simply draw
the bigger pad/copper area in bottom layer in the layout. For example
with a filled circle or a polygon. Don't forget to check solder
stop mask.
Richard Hammerl
Hi there...
large on Bottom layer and small/non-existent on Top layer? If so how
is it done? This is for one component only, not global on the pcb...
Thanks, regards
Lance
stop mask.
Hmmm thanks...
