EAGLE User Support (English) n00b question
  • Subscribers 178 subscribers
  • Views 308 views
n00b question
Richard:
Being a total EAGLE n00b, it seems I can't get the  'Group'  tool to work - the rectangle or multiline just disappears and things  don't act 'grouped'.
Can you assist?
Just thinking, perhaps there should be a separate discussion section for us beginners, just sayin'.
Drew
    0 Former Member over 14 years ago
    On 7/13/2011 9:00 AM, Galactus9 wrote:
    Richard:
    Can you assist?
      Drew
    Hi Drew,
    The group command works a little differently than some other drawing
    programs.
    I usually select the tool that I want (delete, ripup etc) and then
    immediately select the group command, then select the group with the
    mouse and right click (Or the green light) to make it so.
    You can select the group and then the tool also, but you still right
    click to make magic.
    The help system is very good also.
    Doug
    0 Former Member over 14 years ago in reply to Former Member
    I see that (and by the way, it's not explained very well) that WHEN the right click occurs, then a small text box appears that then must be clicked for the action to happen.
    No, I don't agree the HELP is not very helpful. The tutorial is not so good either.
