EAGLE User Support (English) Auto routing between two boards
  • Views 395 views
I am developing a PCB for a Cloud/Weather sensor device that consists of several boards stacked on top of each other. can anyone tell me if there is a way to auto route the nets of each board as well as the pinout of the connectors used to link each board?
I hope the question makes sense to you, if not i'll try and give some more detail.
Thanks.
Ryan.
    0 e14 Contributor over 15 years ago
    See attached example.
    Make each board a seperate entity. Each board holds its respective half of
    the two part connector.
    If you have the same net name on two boards you will get an airwire
    connecting the two boards that will not route due to auto router rules
    regarding the dimension layer. You don't want routing between the multiple
    boards depicted in the board editor.
    In the schematic place text to label the respective signals at each
    connector
    HTH
    Warren
    Thanks.
    Ryan.
    If you have one schematic and one board file with all the separate board
    outlines in layer 20 The autorouter will do the right thing.
    The connectors are easy also, just show them as one connector with nets
    to another connector on the schematic and place them accordingly on the PCB.
    It would help to organize the schematic to look like the PCB.
