EAGLE User Support (English) Obscured text on layer 26 (bnames)
  • Subscribers 179 subscribers
  • Views 392 views
I'm using Eagle 5.11.0.  When working with components on the bottom side of a board layout, I'm having problems with the component names on layer 26 (bnames layer) being hidden by the circuitry on the bottom layer 16.  Is there a way to fix this so that bnames is always on top of layer 16, and is always visible?
  • Richard_H
    0 Richard_H over 14 years ago
    Am 10.08.2011 15:09, schrieb Arley Jackson:
    This might depend on the color settings. What background color do
    you use? Do you use the default alpha blending? You can check and
    modify the settings in the Options/Color menu.
    Richard Hammerl
    0 Former Member over 14 years ago in reply to Richard_H
    I don't find an Options/Color menu selection, only Options/Set or /User Interface selection.  Snapshots of the Options/User Interface dialog with the settings I'm using and the actual problem are shown below.
    This happens on all boards that I work on, not just this one.
  • Richard_H
    0 Richard_H over 14 years ago in reply to Former Member
    Am 11.08.2011 13:26, schrieb Arley Jackson:
      Image:User Interface.png
    The images did not make it to the nntp groups, but I looked on
    eklemetn14 and found the images. The Options/Set/clors menu is
    the correct one. Could you please check whether the option
    "Use Alpha blending" is active or not. Simply toggle it. Does it help?
    Richard Hammerl
    Yes, I had "Use Alpha Blending" checked.  I unchecked it, and the problem has been fixed.  THANK YOU VERY MUCH!
