EAGLE User Support (English) Problem going from schematic to board
  • Views 392 views
  • board
  • eagle
  • pcb_traces
  • schematic
  • question
I am using an AVR-MEGA8-PPTH in a schematic of Eagle v.5.8.0 and I have several pins of the MCU connected to separate LEDs. For some reason, when I switch to board, all those pins become connected together which obviously is a problem as I need to control each of them individually.
Any ideas out there would be greatly appreciated!
GervQC
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    "gervqc" <communitymanager@premierfarnell.com> wrote in message
    news:502524455.1431315874271167.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    >I did the wiring of those components again and now everything looks fine
    >when I switch to board.
    I guess you may have copied the wires on first attempt.. If you copy a
    single signal on schematic (not group copy), it will keep the same netname
    and hence be connected.
    I did the wiring of those components again and now everything looks fine when I switch to board.
    Thanks Warren,
    GervQC
    them individually.
    GervQC
    It's likely an airwire is just going over the other pins as it heads to
    where it's truely connected. Start routing and it should become clear.
    Warren
