EAGLE User Support (English) Inconsistent behavior of DISPLAY command?
  • Views 354 views
KE5FX
KE5FX over 14 years ago
Another quick question that probably comes down to pilot error: in setting up some key macros, I'm finding that the commands "display tdocu" and "display -tdocu" turn the tdocu layer on and off as expected, while "display unrouted" turns off all layers except unrouted.  There doesn't seem to be a straightforward way to toggle the unrouted wires on and off without affecting other layers.  Is there a reason and/or workaround for this behavior?  Thanks!
  • KE5FX
    0 KE5FX over 14 years ago in reply to Richard_H
    On 9/26/2011 2:17 AM, Richard Hammerl wrote:
    Am 24.09.2011 11:55, schrieb John Miles:
    DISPLAY unrouted and DISPLAY -unrouted
    should work the same as for all other layers.
    Could you please check whether there is an alias defined that
    is named unrouted?
    Thanks for the hint -- I did have an alias called Unrouted_Only, and
    deleting it fixed the problem.  Didn't realize that abbreviations
    applied to user alias names, or that they took precedence over the
    built-in names.
    -- john
  • Richard_H
    0 Richard_H over 14 years ago
    is named unrouted?
    Richard Hammerl
