EAGLE User Support (English) Re: "Transparent" windows under ubuntu 7.04
  • Subscribers 187 subscribers
  • Views 393 views
  wrote:
I am a fairly new migrator from Windows. I have reasonable  experience
running Eagle under Windows and I do have an Eagle win/linux license.
I did install Eagle the beginner-safe way using Synaptic, it loaded the
packages and I think that it installed Eagle as it should.
At first I thought something was absolutely wrong with the installation
package, since the dialog windows were completely white. After fooling
around, I relized that the text was not invisible, only "transparent",
meaning that if I placed it over a dark area on the desktop, I can read.
Managed to finish the installation, works as expected, BUT all eagle windows
still has this weird transparent behaviour so that underlying windows are
"glowing through" and that the brightest colour of any wiondow spot in any
specific location takes precedence.
This means that it almost impossible to configure the program.
Any suggestions?
I did the same operation to install EAGLE in UBUNTU 8.04 getting the
same results: all the windows are transparent and it's no possible to
config the product that remains unusable....Can you suggest some
corrections or actions?
Many tanks
eibike-it
  • Richard_H
    Richard_H over 18 years ago
    the packages and I think that it installed Eagle as it should.
    installation package, since the dialog windows were completely white.
    After fooling around, I relized that the text was not invisible, only
    "transparent", meaning that if I placed it over a dark area on the
    windows still has this weird transparent behaviour so that underlying
    windows are "glowing through" and that the brightest colour of any
    wiondow spot in any specific location takes precedence.
    Any suggestions?
    Many tanks
    eibike-it
    Take a look at: http://www.cadsoft.de/faq.htm.en#07041701
    Richard Hammerl
    Any suggestions?
    Many tanks
    eibike-it
    Some video cards or on board video hardware have bugs in the drivers.
    What video hardware and driver do you have?
    Try disabling desktop effects.
    Paul R.
