EAGLE User Support (English) license question and autorouter not using inner layer
  • Views 210 views
Hi
I have a standard edition license, and would like to know if I can use my copy of eagle on more than one machine. I am the only user of the software but want to be able to use it at work and at home, as I sometimes work from home.
Also using the autorouter with a board with 4 layers, one inner layer is a supply layer and the other is a routing layer, the inner routing layer is not used. Does anyone know why this is and what I can do to change it?
Michael
    On 10/4/2011 6:27 AM, Michael Taylor wrote:
    Hi
    Michael
    Hi Michael,
    You can install your EAGLE license on more than one machine as long as
    those machines are under your control.
    In the Autoruter settings-> General tab. Set a direction of the routing
    layer and make sure the $(supply) layer is set to a direction of N/A.
    hth,
    Jorge Garcia
    Cadsoft Support
