EAGLE User Support (English) Draw Lines vs Electrical Connection
  • Subscribers 187 subscribers
  • Views 170 views
jafriede
jafriede over 14 years ago
This is my first board layout in Eagle (actually a redraw from older software).  I only have one true "component" on the board which is a 2 pin AMP connector.  The holes on the board were done using "draw a hole".  I first did a hole in layer 20 and then another in layer 1 (top).  I also drew some lines to build up copper in the four quadrants of the large hole.  I now need to make an electrical connection between the connector and the large hole / top 2 small holes.  When I try to use "define electrical connection", it will not recognize the copper I defined with the draw line/circle.  How do I do this?  Also, the large hole and 4 surrounding holes need to only have copper on the top layer.  This is a contact plate used in a mechanical system.  Any guidance would be appreciated.
