EAGLE User Support (English) Drill File Problems
  • Subscribers 178 subscribers
  • Views 201 views
Drill File Problems
My board house requires drill file to output to 3 decimal places. My Cam
processor and stuff is defaulting to 4 decimal places. I tried changing the
Excellon section of my eagle.def and added the line Decimals = 3, but to no
avail. It still outputs to 4 Decimals. Any Ideas?
  • Richard_H
    Richard_H over 17 years ago
    I suppose they want to have a resolution of 1/1000 inch instead
    of 1/10.000 inch.
    In this case you could the following section:
    Type     = DrillStation
    Long     = "Excellon drill station"
    Init     = "%%\nM48\nM72\n"
    Reset    = "M30\n"
    ResX     = 1000
    ResY     = 1000
    ;Rack     = ""
    DrillSize  = "%sC%0.3f\n"        ; (Tool code, tool size)
    AutoDrill  = "T%02d"             ; (Tool number)
    FirstDrill = 1
    BeginData  = "%%\n"
    Units    = Inch
    Select   = "%s\n"                ; (Drill code)
    Drill    = "X%1.0fY%1.0f\n"      ; (x, y)
    Info     = "Drill File Info:\n"\
                "\n"\
                " Data Mode         : Absolute\n"\
                " Units             : 1/1000 Inch\n"\
                "\n"
    This should work for them.
    Richard Hammerl
