EAGLE User Support (English) Import .SCH files from ExpressSCH?
  • Subscribers 178 subscribers
  • Views 543 views
I've just downloaded Eagle, having used ExpressSCH and ExpressPCB. I'm
having a bit of trouble getting started, even adding a component!
I've now found the tutorial, and it looks tough, but I think it's going to
be worth the effort.
So, my main question now is: can I import the .SCH files from ExpressSCH?
Nigel M
If my question is about apples, please don't suggest bananas
    If you don't find a converter in the eagle ULP download area no body has
    written one.
    One of the many good things Eagle has is access via ULP and SCR programs
      to all of the internal data structures.
    If you have large amounts of files in ExpressPCB you want to transfer
    them and can locate the file format of ExpressSCH you or somebody could
    write a translation program.
    But the best bet it to redo it manually and then export the net list
    from both and compare for differences.
    Paul R.
