EAGLE User Support (English) How to define solder mask for a nut
  • Views 403 views
PLA
PLA over 14 years ago
I have to define a SMD solder mask on a round plated-through pad for a nut.
See data sheet:
http://kvt-de.comu.de/katalog/item.jsp?sapartnr=300152035&kvtartnr=KF2-M2+GEGURTET+MIT+KLEBEPUNKT
Hoping on helpful tips.
PL
    a nut. See data sheet:
    http://kvt-de.comu.de/katalog/item.jsp?sapartnr=300152035&kvtartnr=KF2-M2GEGURTETMIT+KLEBEPUNKT
    PL
    Solder mask will be created automaticaly for pads in library parts or vias
    placecd on the board.
    Turn on the layers tStop  bStop to confirm it is what you need.
    If you are using HOLE for the nut and manually drawing the copper around it
    you should place a filled circle over the hole, on the tStop layer
    HTH
    Warren
    news.cadsoft.de
