EAGLE User Support (English) Library/Footprint for IDC connector
  • Views 1038 views
I need to use a 35-pin, 2mm IDC connector in my schematic. Any recommendations on which library to use? Not sure which default eagle library( if it has IDC connectors) to use to look for IDC connectors.
Abhishek
    Abhishek Roy wrote:
    Abhishek
    For assistance in searching for parts in the supplied libraries have a look
    at the FAQ on the Cadsoft website.
    18. Finding Libraries and Components
    news.cadsoft.de
    On 10/16/2011 06:08 PM, Abhishek Roy wrote:
    Abhishek
    You are doing it backwards. First find a connector that you can find in
    stock and at the price target. This would include tools to do the crimp.
    Then look in the lib's and quite a few have connectors.
    What ever you find you need to verify it with the data sheet. This is
    about as hard or harder then making the part from the data sheet and you
    save time not looking for it. I use a spread sheet to calculate  all of
    the x,y from the center of the part and place the lines and pads using
    that info.
    Paul R
