EAGLE User Support (English) How to suppress unused layers?
  • Subscribers 187 subscribers
  • Views 323 views
As I manually route a trace, I use the center mouse button to move from
layer to layer.  I only have two layers, though, and all the intervening
layers in the layer list get in the way, slowing down layer selection.  Is
there a way to turn them off, so I only have Top and Bottom visible?
Thanks.
  • Richard_H
    Richard_H over 18 years ago
    Thanks.
    Please go to Edit/Design Rules, Layers tab.
    Change the current Layer Setup slightly and click the "Apply" button
    Now restore the original Setup - this would be (1*16) for a simple
    two layer board - and close the Design Rules window with "Ok".
    Now Top and Bottom should be displayed only in the menu.
    Alternative:
    Use the SET USED_LAYERS command to determine which layers should
    be displayed, for example:
      SET USED 1 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 44 45 46
    Richard Hammerl
