EAGLE User Support (English) How to transfer library ?
  • Views 385 views
image  Somehow, in the process of changing the name of my personal library to move it to the top of the list to make it more easily accessible, I managed to make it no longer be listed at all in the main library( the library that is accessed from the Control Panel). My personal library is still listed in my ADD library ( the library accessed by clicking on the ADD button while working in the schematic. Can someone tell me how to move a library from the ADD library back to the main library in the Control Panel?
Thank You,
Jeff
    Hi Jeff,
    You can either:
    1) Copy your personal library into the main library directory $EAGLEDIR\lbr
    or
    2) Go to,    OPTIONS ->>  Directories... ->>  and add a semicolon " ; " after the default Library path "$EAGLEDIR\lbr"  . The semicolon lets you add multiple paths.
    For example, the following will pull ".lbr" files from two folders:
    $EAGLEDIR\lbr ; C:\Documents and Settings\user2\My Documents\eagle\MyCustomLibraries
    I hope this helps!
    the main library in the Control Panel? Thank You,
    Jeff
    I think you may now have your personal library named without a .lbr
    extension.
    That will make it dissappear from the control panel view but not the ADD
    view.
    HTH
    Warren
    news.cadsoft.de
