EAGLE User Support (English) POLYGON as PAD for PART
  • Subscribers 179 subscribers
  • Views 467 views
I need to create custom PAD geometry using the POLYGON tool in order to make
a PART.
The problem I am having is it is not letting me NAME the copper that is
created nor assign a PIN.
I created the PART by dropping a SMD PAD on the copper.... however, MIRROR
does not swap the copper (polygon) board side.
Can someone help?
Thank you!
-charlie
    Someone please answer...
    "Charlie Van Dien" <vandien@bellsouth.net> wrote in message
    news:g6ah2s$624$1@cheetah.cadsoft.de...
    make a PART.
    Can someone help?
    Thank you!
    -charlie
    Former Member over 17 years ago
    Do a search in all groups for SMD, you will find a lot of information.
    r
    None were found... that's why I posted... seems by now I could have just
    been given the answer of the direction, instead of just telling me to "look"
    when I've already done that.
    -c
    "Ing. J.M. Rafetseder" <jrafetseder@hotmail.com> wrote in message
    news:g6foel$jmn$1@cheetah.cadsoft.de...
    r
    autodeskguest over 17 years ago in reply to autodeskguest
    just been given the answer of the direction, instead of just telling
    me to "look" when I've already done that.
    -c
    Just looking for "polygon" in this newsgroup, I found the following post
    fairly easily.  Make sure your newgroup reader is accessing all the messages
    in the group's history.
    Bert Menkveld
    Date: Nov 7, 2006
    Subject: Re: Polygon pads
    Jake P wrote:
    "Paul Romanyszyn" <pgr@arcelectronicsinc.com> wrote in message
    news:eiqp8b$sb$1@cheetah.cadsoft.de...
    Jake P wrote:
    I was wondering if any one knows how to make a pad from a polygon.  The
    verticies of the polygon are as follows.
          Vertex X Y
          1 -3.3565 3.285
          2 0.808 3.285
          3 0.808 1.056
          4 3.3565 1.056
          5 3.3565 -3.285
          6 0.2475 -3.285
          7 0.2475 -0.94
          8 -3.3565 -0.94
    As a reference this is for a Freescale part #MC13214 which can be found
    here:
    http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MC13214
    Not supported in eagle yet. Polygons can not be signals.
    You can add a stop mask and cream polygon to the lib.
    For the pad put one smaller one and then covert your data to a script
    using relative points. Using the mark on the center of the pad then run
    the script to draw the polygon then name it the net name of that pad.
    Paul R.
    Ok for example if i put a pad with the dimension of 1 x 1 with the center
    at
    the center of the part what would i have to do next.  I am fairly
    experienced with the graphical end of eagle but when it comes to scripts I
    am completly lost.
    Jake P
    Place a mark on the center of the pad.
    Either type or paste into the command line or save a file with would
    look like the following.
    polygon (r10 r10) (r10 r200) (r50 r200) (r50 r10) (r10 r10);
    Before you run it you need to select the polygon tool and set the
    bend,layer and other options.
    If the grid is set to mil then the above should draw a rectangle 40mil
    by 190mil rectangle 10mil above and to the right of a mark.
    You will have to convert your (x y) pairs to the correct relative value
    I would use a spread sheet for the math.
    Review the online help in the keyboard and mouse section and move for
    keyboard entry of data points.
    Paul R.
