EAGLE User Support (English) Draw a Schematic diagram that does not use PCB footprints
  • Answers 2 answers
  • Subscribers 187 subscribers
  • Views 668 views
  • layout_schematics_with_no_pcb_footprints_associated
mbdssysm
mbdssysm over 14 years ago
Hi
Some times as part of a project certain parts of the design will be hard wired and these need to be documented ,
When designing a schematic symbol, Is there a way to make schematic symbols without an associated pcb footprint?
For example:
connecting mains filter, switch and transformer together that are not on a pcb.
Summary:
Do I need to create a separate circuit diagram for these components or is there a way of including them on the circuit diagram but not on the pcb layout?
Help much appreciated
Stephen
    Am 21.11.2011 14:53, schrieb Stephen Mottley:
    If you do NOT want to create special library parts for that, please see
    the thread 'Adding parts to schematic not on the board' in
    'eagle.suggest.eng', especially my answer from 2011-03-18, where I
    attached a corresponding ULP.
    Andreas Weidner
    I made a lbr containing a lot of symbols not on brd. Description is in
    german. You can use it as an example. Use 7zip to unpack.
    r
    HTL-Symbols-Not-On-Board.7z.zip
