EAGLE User Support (English) Copy group using the ctrl and alt keys has a bug
  • Subscribers 178 subscribers
  • Views 207 views
Hi Support,
I'm using Eagle 5.1.0 for windows.  Normal grid .050 inches, alternate .025
inches. Copying a group, two crossed lines .150 inch long on the dimension
layer. Lines intersect on an alternate .025 inch grid point.
Hit CTRL and ALT then right click to set origin of the copied group to the
center point of the two lines, which were on .025 grid.  The cursor is
offset from the copied elements as though it was on the normal grid when the
copy was invoked, not the alternate grid.
So the selected center of the copied group does not follow the cursor
position.
If I set the normal grid to .025 I get the expected behavior that the center
of the lines follows the cursor.
M. Chadwick
  • kcadsoft
    kcadsoft over 17 years ago
    On 07/25/08 22:36, Mike Chadwick wrote:
    Hi Support,
    position.
    Fixed for version 5.1.3.
    Klaus Schmidinger
    Hofmark 2                               Email:   kls@cadsoft.de
