EAGLE User Support (English) In schematic: net vs wire
  • Subscribers 177 subscribers
  • Views 343 views
In the  v5.1 schematic, when do I use net vs wire?
Steve
    Steve
    Wire is just for drawing lines. Net must be used for all signal connections.
    John G.
    On Sat, 26 Jul 2008 11:23:46 +1000, John Giddy <jgiddy@bigpond.net.au> put
    together some random words that came up with:
    Steve
    John G.
    Yet when I use wire on the net layer, Eagle considers it a net and assigns the
    wire a net number.
    Steve
    Steve
    John G.
    wire a net number.
    Steve
    Net has the benefit of automatically making connections to pins and
    other nets. Wire doesn't do this, so is more liable to errors.
    Eagle has rules which one should adhere to if the least problems are to
    be faced.
    John G.
    On Sat, 26 Jul 2008 22:19:19 +1000, John Giddy <jgiddy@bigpond.net.au> put
    Steve
    John G.
    wire a net number.
    Steve
    be faced.
    John G.
    Thanks, John.  I tried the net instead of the wire, and I will be using the net
    from now on.  The difference is obvious.
    Steve
