EAGLE User Support (English) 4layer design support
  • Views 380 views
  • eagle
  • pcb
  • cam
  • layer
  • via
  • 4
  • gerber
I am now using eagle.
In layer setup i used this equations.
[3:1*2*3*16:2]
i am not a proffesional worker.
So can u please generate a equation 4 layer set up.
i need connections form Top layer to 3rd layer.
3rd layer to bottom layer.
2nd layer to bottom layer.
Could you please generate layer setup
    Am 05.12.2011 11:30, schrieb Sirosh Sivaraman:
    Do you REALLY want so-called 'blind vias', meaning that these go from
    the outside to a certain inner layer AND STOP THERE?
    If yes, then you SHOULD ask your circuit board manufacturer how the
    layers should be constructed: Not every manufacturer can create all
    theoretically possible layer stacks. Try
    or
    but both MAY be very expensive or problematic to manufacture. Exchanging
    the contents of layers 2 and 3 results in a much nicer layer stack, e.g.
    But, as John Friede already pointed out, CONTINUOUS vias (going
    completely THROUGH the board) are much cheaper and less error-prone. If
    you can live with these, try the layer stack that John suggested:
       (12+316)
    Andreas Weidner
    Some example stackups are given on page 131 of the manual.  The one I am
    using for 4 layers is (12+316).  The parenthesis indicate that vias
    are continuous (this is more economical than blind vias).  I believe for
    blind vias you use brakets [] instead of parenthesis.
