EAGLE User Support (English) [SOLVED] Problem trying to install Eagle 6 over Linux Ubuntu 11.10
  • Subscribers 190 subscribers
  • Views 1396 views
Trying to run installer I got on the terminal "error while loading shared libraries: libpng14.so.14: cannot open shared object file: No such file or directory".
Ubuntu 11.10 only have libpng12 on their repositories.
I build libpng14 from sources but my system is 64bits and trying to run installer I got a message complaining about libpng14 ELF for 64bits.
I try tu build libpng14 for 32bit target without luck because libtool can't generate shared libraries (using target i386) on my ubuntu system.
Any suggestion?
    0 e14 Contributor over 14 years ago in reply to zainka
    Hi Vidar
    Sorry for opening a somewath old solved thread, but yesterday I decided
    to try latest version myself.
    No Worries
    I run into the same problems as many others regarding libpng using above
    solution. Must admit that I found it strange though that cadsoft did not
    present solutions that work for most of the top 10 distroes without
    tweaking the system. Question to cadsoft, which does have a great
    product, is if future releases will be recompiled using libpng15 as is
    the most commonly used version for latest distro releases. Above methode
    is at best a working temporarily workaround.
    However, After installation went beyond libpng14 problem, I run into
    another missing lib problem. I have Linux Mint 10 Julia running, and it
    seems libssl.so.1.0.0 is not available. I know its a requirement but
    could not find a good way to install it.
    The 5.91 series of betas brought the libraries and you used a special
    wrapper script to have EAGLE use them. The easiest way to get those four
    libraries on your system is to copy them from the installed betas into
    your usr/lib folder.
    E-mail me at support@cadsoftusa.com and I'll send the libraries to you.
    I know there are some legal reasons as to why those libraries can't be
    included with EAGLE and I figure there is a similar issue with posting
    them anywhere other than there original locations. That's why I didn't
    attach them.
    hth,
    Jorge Garcia
    Cadsoft Support
  • dukepro
    0 dukepro over 14 years ago in reply to zainka
    Dependency-hell: a good reason to statically link eagle.
    On 01/18/2012 04:30 AM, Vidar (Z) wrote:
    On 12/19/2011 07:39 PM, Morgan Leijström wrote:
    >> Alvaro Aguirre wrote:
    >>> Solved using:
    >>> || Terminal ||
    >>> | cd /tmp
    >>> wget http://slackware.osuosl.org/slackware-
    >> current/slackware/l/libpng-1.4.8-i486-1.txz
    >>> cd / sudo tar xf /tmp/libpng-1.4.8-i486-1.txz
    >>> sudo chmod 777 /install/doinst.sh
    >>> sudo ./install/doinst.sh |
    >> Thank you Alvaro image
    >> I used your method to "solve" this same issue on Mageia.
    >> Works so far, but:
    >> Beware elder libpng files get replaced in /usr/lib/,
    >> so it is a good idea to backup them first!
    >> (See inside that /install/doinst.sh)
    >> Is there any official workaround/solution yet?
    I could uppgrade to mint 12 and hope that solves it, but I find it
    rather strange that one have to reinstall a one year old computer just
    to have a new version of a existing program running.
  • zainka
    0 zainka over 14 years ago in reply to e14 Contributor
    >> Solved using:
    >> || Terminal ||
    >> | cd /tmp
    Works so far, but:
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Solved using:
    || Terminal ||
    | cd /tmp
    Works so far, but:
    Morgan Leijström, Tribun AB
    Solved using:
    Terminal
    cd /tmp
    wget http://slackware.osuosl.org/slackware-current/slackware/l/libpng-1.4.8-i486-1.txz
    cd /
