EAGLE User Support (English) PLEASE help Uninstalling Eagle from my Mac?
  • Subscribers 189 subscribers
  • Views 1188 views
  • eagle
  • mac
  • uninstall
7h3p1930n
7h3p1930n over 14 years ago
Im having real trouble since trying to instill version 6.
After installing and clicking on the egale icon, it just pops up with the "this program has quit unexpetedly" and then closes agian. Iv tryed to uninstall it by removing all the all the files like bin and the icon, but then when I try and reinstall my older version 5 agian it pops up and tells me i already have a later version installed?
At this point I just want to get rid of any eagle files that are learking somewhere!?!? and have a fresh install of 6 image
  • AnalogNotes
    0 AnalogNotes over 13 years ago in reply to gbulmeruk
    Seems like the same crashing problem I'm having (a year later!) with OS X 10.5.8.  If you click on the "Report" button on the crash dialog, then choose the "Problem Details" tab, you may find out why the crash happened...
    Interestingly, I have EAGLE 5.12 installed at the same time as 6.3, and 5.12 is fine.  Since I never got 6.3 to work, maybe it didn't install any incompatible files...
    Doug
  • nlarson
    0 nlarson over 13 years ago in reply to gbulmeruk
    G Bulmer, just touching base with you to see if you were able to resolve your above issue?  Let us know. Thanks!  Ps. sorry for the late response.
  • gbulmeruk
    0 gbulmeruk over 14 years ago in reply to e14 Contributor
    I was using Eagle 5 for several versions, I installed Eagle 6.1.0 on a Mac PowerBook Pro (2.2HGz Intel Core 2 Duo) running OS X 10.5.8 on Jan 12th.
    I believe it worked at the time. I have been using a different machine since then.
    I tried to open an eagle file today by clicking on it, and I get the same sort of message "Eagle quit unexpectedly' and when I try to report to Apple, it says the report can't be sent try later.
    I found a thread http://www.eaglecentral.ca/forums/index.php?t=rview&goto=140670&th=45180
    which says uninstall and re-install. I deleted the entire Eagle folder.
    I re-installed. It still des not work.
    0 e14 Contributor over 14 years ago in reply to nlarson
    Am 15.12.2011 16:40, schrieb Nicole Larson:
    Hi There - You might try asking our CadSoft EAGLE expert, Richard Hammerl this question.  If you post to his expert thread: (click here (/message/5177)) he should be able to help you with your question.  Hope this helps!
    Nicole, element14 Community Manager
    To get some help, at least he should reveal what hard- and software he
    is using.
    Joern Paschedag
  • nlarson
    0 nlarson over 14 years ago
    Hi There - You might try asking our CadSoft EAGLE expert, Richard Hammerl this question.  If you post to his expert thread: (click here) he should be able to help you with your question.  Hope this helps!
