EAGLE User Support (English) Is there a way to convert back to Eagle 5 format?
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 1385 views
ClaveFremen
ClaveFremen over 14 years ago
I didn't make backup copy of a project I'm working on not expecting problems from the new 6.0 version...
Sadly there are problems that are preventing me to continue with Eagle 6, is there a way to convert back .brd and .sch back to Eagle 5 format?
Or has been the RCL capacitors problem listed in known and urgent problems to be fixed?
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    On 12/19/2011 4:38 PM, Sander Sassen wrote:
    Well, I got a similar issue. I'm sharing a design with someone else and he has just updated to 6.0 hence I can't read any of his files unless I upgrade too, which I'm not really motivated to do as 5.10 does all I require (and I would need to pay for the upgrade of course).
    Saving to an older format IS pretty common since about '89, the fact that Eagle doesn't support this is somewhat mind boggling.
    So, is there a way to convert 6.0 files to 5.10?
    Try using the export-board and export-schematic ULPs that are up on the
    website. There will probably be a couple of errors on import into V5 but
    otherwise should import ok.
    hth,
    Jorge Garcia
  • ClaveFremen
    0 ClaveFremen over 14 years ago in reply to e14 Contributor
    As I've already stated I don't have a backup...
    I'm not used to programs that can't revert...
    Eagle is a fantastic piece of software, I simply adore it, I've learned to use it in less than a week and it's so powerful.
    But the lack of the possibility to save in the older format, at least in the early deployment stage of a major release, is a serious problem...IMHO
    John Friede wrote on Mon, 19 December 2011 16:22
    Yes and no.  AutoCAD and most Microsoft products have options to save
    as earlier versions.
    Yes, some software can do that.  But enough software doesn't, and then
    there can always be bugs, that relying on that is just stupid.  People that
    don't do backups deserve to have their data deleted, and it usually works
    out that way eventually.
    Saving to an older format *IS* pretty common since about '89, the fact that Eagle doesn't support this is somewhat mind boggling.
    On 12/19/2011 7:51 AM, Olin Lathrop wrote:
    Element 14 User wrote on Sun, 18 December 2011 19:54
    Duh!  It is common for new versions of software to be able to read data
    files from old versions but only write the new format.  Even if you weren't
    somehow aware that Eagle 6 uses a totally new XML based format, it would
    have been smart to archive a snapshot before upgrading.
    In any case, just restore to your latest regular backup as Tilmann said.
    You do make regular backups, right?
    Yes and no.  AutoCAD and most Microsoft products have options to save as
    earlier versions.  That being said, backups are essential.  I use
    Crashplan http://www.crashplan.com/ to backup my files & libraries to
    both my home computer and their cloud storage (paid version).  It is
    real easy to use and so far has been very reliable.  You have access to
    different versions of your files, not just the latest one.  It's similar
    to more popular ones like Carbonite but is cheaper and more flexible.
    Just a suggestion (I don't work for them!)
    Simply use one of your regular daily backups - ideally of the last day
    before moving to 6.0.
    format?
    You might try one of the export ULPs to generate a script which you can
    use to import the design in 5.11 again. (See download section.)
    Tilmann
