EAGLE User Support (English) eagle library problem
  • Views 312 views
I want to create a pad size 0.45mm. how can I do this in eagle.
    Create a library for yourself and use the package editor to place a pad
    of any shape and size. You could start by copying the "solpad.lbr"
    library and modifying to what you need.
    Here is a pretty good tutorial on how to make a library with custom parts:
    http://www.instructables.com/id/How-to-make-a-custom-library-part-in-Eagle-CAD-too/?ALLSTEPS
    Making custom parts is really very easy once you get the hang of it.
    The main thing  to remember is that a component is made up of three thigs:
    1.) device
    2.) package
    3.) symbol
    The device is the top level that contains the package and the symbol.
    With your new library open, you can use the Eagle control panel to copy
    a package or device to your new library by simply right clicking and
    selecting "copy to library".  Now that it's in your custom library, you
    can edit, rename, etc. without affecting the library you copied it from.
      There is more to it but I suggest you read through the Eagle Tutorial
    and watch the tutorials on You Tube.  That's how I learned it.  Good luck
