EAGLE User Support (English) too big diameter using Drillegend in Eagle 6.0
  • Views 258 views
  • diameter
  • Table
  • drillegend
I just started Eagle 6.0.0 and tried to extract the dimensions of the drills and holes using the drillegend.ulp.
The used schematic was generated with Eagle 5.11, but trying a schematic from version 6 after that showed the same behaviour.
The generated table showed much to big diameters. Using version 5.11 worked fine.
Does someone know about this bug and/or has a solution for this problem?
Thanks for every hint.
With best regards
Mario
    On 12/20/2011 5:54 AM, Mario Fischer wrote:
    With best regards
    Mario
    Hi Mario,
    Cadsoft Germany is working on this one already.
    Thanks for the notice.
    Best Regards,
    Jorge Garcia
