EAGLE User Support (English) move with specified angle, in script file
  • Subscribers 178 subscribers
  • Views 393 views
esilviu
esilviu over 17 years ago
In a script it's possible to use "move" command and specify the angle, or it
needs move + rotate commands? (when you use the button "move", it's possible
to set the angle too)
  • Richard_H
    Richard_H over 17 years ago
    You have to use MOVE and ROTATE in the script file, for example:
      MOVE R1 (200 20);
      ROTATE =RMS120 'R1';
    Richard Hammerl
