EAGLE User Support (English) Problem with Drill Legend ULP
  • Views 417 views
Hi, I ran the Drill Legend ULP in that past and it always worked well.  Now when I run it I get circles with slashes for all the holes except for one part that I recently created.  Any idea's?
Paul
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Paul Czarapata wrote:
    Thanks Warren, you nailed the problem. I am still switching over from
    a previous system and learning my way around. I am using V 5.11 but
    about to upgrade. Thanks again,
    Paul
    V6 is troubled at the moment so it would not be wise to upgrade just yet.
    There is currently no v6 that is production ready and I suspect it will be
    March before its worth laying out money for.
    The experienced group that usually provides feedback to the beta forum has
    gone quiet. I suspect that is because they  have walked away from v6 until
    CadSoft release something worth the time to evaluate without running into
    errors that should have been detected in-house. That's my position.
    What is likely to be the final version of V5 (5.12) is available and that
    fixes some minor errors in 5.11 so you may care to grab that and have the
    best v5 version.
    Warren
    news.cadsoft.de
    Thanks Warren, you nailed the problem.  I am still switching over from a previous system and learning my way around.  I am using V 5.11 but about to upgrade.
    Thanks again,
    Paul
    except for one part that I recently created. Any idea's? Thanks,
    Paul
    Circle with slash indicates no symbol has been assigned to that drill
    diameter.
    See Manual and search for 'drill plan'.
    Ensure you are viewing the correct layer. (114)Drill Legend and not (44)
    Driills
    Are you running the same version as in the past or is this v6?
    Warren
    news.cadsoft.de
