EAGLE User Support (English) How to open project in eagle 5.4 which is created in Ver6.0
  • Views 563 views
When I use Ver6.0 in win7 64bit it always crashed and have to restart app. to solve this big issue. So i go back to eagle5.4 version.
But it has another problem i can't open the project in Ver5.4 which is created in Ver6.0.
So who can help me to close this issue--open the project created in Ver6.0 in Ver5.4 eagle??
Thanks a lot.
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Arrgh - was going to mention those files. However, I would've gone to the backup I made before upgrading to 6.0 that I'm sure everyone did image
    (No, I didn't make a backup either image - but then I do have Time Machine doing them for me)
    If all that fails, delete the project.sch and project.brd files (or move
    them) and rename your project s#1 and project b#1 files to project.sch and
    project.brd. You may need to work on them to make them consistent.
    "Jason Tribbeck" <noreply-7194@element14.com> wrote in message
    news:462497441.11431325235843694.JavaMail.jive@flcspu-csapp-01.premierfarnell.com...
    Since the file formats have changed, you won't be able to open any .brd or
    .sch files that have been saved in 6.0 - and the eagle.epf file will also
    not be openable (the same is true of the library files - if you've edited
    them).
    If your .brd or .sch files are still in 5.x format, then you may be able
    to delete the eagle.epf file and try opening the .brd/.sch.
    If you created a completely new project in 6.0, then you will not be able
    to open that in 5.x. (Since I've done a bit of work with the 5.x format, I
    have contemplated writing a converter for 6.0 back to 5.x, but as I don't
    have the need for it, it's not a priority for me).
    Since the file formats have changed, you won't be able to open any .brd or .sch files that have been saved in 6.0 - and the eagle.epf file will also not be openable (the same is true of the library files - if you've edited them).
    If your .brd or .sch files are still in 5.x format, then you may be able to delete the eagle.epf file and try opening the .brd/.sch.
    If you created a completely new project in 6.0, then you will not be able to open that in 5.x. (Since I've done a bit of work with the 5.x format, I have contemplated writing a converter for 6.0 back to 5.x, but as I don't have the need for it, it's not a priority for me).
