EAGLE User Support (English) How to change min D-Code for Gerber files?
  • Views 614 views
  • board
  • eagle
  • cam
  • gerber
  • question
I am fairly new to creating Gerbers.  A PCB vendor wants me to change the min D-code from .1 mil to 2 mil.  I have looked through Eagle 5.11, but am not sure how to change this value or what specifically this value represents.  I think it is x, y coordinates for the dimensions, and vias, but it needs to be rounded up to 2mil.  Any recommendations would be greatly appreciated.
Todd
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Paul Romanyszyn wrote:
    Take a look at your polygon widths. You can look at the Gerber files
    with a text editor and see what section has the small D-code. cut
    other sections out and view the result with a Gerber viewer to see
    where they are being generated. It also could be coming from rotated
    smd pad's
    Paul R
    Running  statistic-brd.ulp can help  locate small sizes used in a polygons
    etc. and provide you with a net name.
    It is then a simple matter to show(highlight) the net name on the board..
    Results from statistic-brd.ulp in are in millimeters
    Warren
    news.cadsoft.de
    with a text editor and see what section has the small D-code. cut other
    sections out and view the result with a Gerber viewer to see where they
    are being generated. It also could be coming from rotated smd pad's
    Paul R
