EAGLE User Support (English) How can I use dimension tool to get distance between two vias?
  • Views 1527 views
  • dimension
osmaneralp
osmaneralp over 14 years ago
I've been experimenting with the new dimension tool in V6. I want to show the distance between two vias. The vias are used as holes for screws that attach to an enclosure. The dimension tool seems to work only on objects that are on the dimension layer (20). How can I get the dimension tool to show dimensions of objects on other layers?
TIA,
Osman
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    Il 11/01/2012 12:12, Warren Brayshaw ha scritto:
    The manual says to hold the CTL key. Does that do what you need?
    As far as I know it works only for on-grid objects.
    Marco
    TIA,
    Osman
    Warren
    news.cadsoft.de
    I had the same problem. I solved in this way:
    1. with info command write down the coordinate of both vias
    2. draw a line on layer 20 between the two points
    3. using the dimension tool create the dimension of the dummy line
    4. delete the dummy line
    I know it's a workaround, any CAD but EAGLE permits to define the snap
    points type of the dimension marks (edge, center, hole, etc...).
    HTH
    Marco
