EAGLE User Support (English) Socket & Part
  • Views 324 views
Socket & Part
I have a DIL socket and a programmable part that goes in the socket. I want the socket and the part on the schematic & BOM but only the socket on the PCB. How do I do that, gracefully?
    0 e14 Contributor over 14 years ago in reply to e14 Contributor
    That works quite nicely, thanx.
    1) Make a library device that has a symbol for the programmable part  and a
    package for the socket.
    2) Make a  second device ( a symbolic device) for only the socket.  It could
    simply be text "In 20 pin socket"  surrounded by a rectangle .This device
    has no package.
    Set the attributes as required for BOM generation for both devices.
    Add to the schematic:
    1) the programmable part. Which has all  the pins which you connect to other
    parts
    2) the socket device.
    On the board you see a socket with airwires to the correct pins.
    The silk screen should show the socket outline and the name will be that of
    your programmable part eg  IC2
    HTH
    Warren
    news.cadsoft.de
