Hello everybody.
Just to ask, how to make the footprints Pad bigger ?
This is the footprints.How can I make it to become like in below ? Or perhaps bigger abit ?
Is it possible ?
Hello everybody.
Is it possible ?
Well, thanks.I manage to change it !
Is there any free full version software for students ?
Date: Sat, 28 Jan 2012 10:53:58 +0000
Subject: - Re: Components Footprints Pad
created by Jason Tribbeck in EAGLE Support (English) - View the full discussion
Hi, If the sizes of the pads are set to 'auto', then it's a DRC setting which determines how much bigger they are. In the DRC, select the 'Restring' tab. Then, change the Top and Bottom (and Inner, if you're using >2 layers and need it) minimum value for pads to the minimum diameter you need - or you can make it a percentage of the hole size. Note that this will affect EVERY pad. If you want a specific component to be a different size, then what I do is make a copy of the library and change the pads one by one (it takes a bit of time though!)
Reply to this message by going to element14
Start a new discussion in EAGLE Support (English) at element14
Sitemap | Feedback & Support | Contact Us | Terms of Use | FAQ | About element14
**************************Disclaimer**************************
The contents of this e-mail and any file transmitted with it are confidential and intended solely for the individual or entity to whom they are addressed.
The content may also contain legal, professional or other privileged information.
If you received this e-mail in error, please destroy it immediately.
You should not copy or use it for any purpose nor disclose its contents to any other person.
The views stated herein do not necessarily represent the view of the Company.
Please ensure you have adequate virus protection before you open or detach any documents from this transmission.
The Company does not accept any liability for viruses.
Premier Farnell plc
150 Armley Road
Leeds
LS12 2QQ
Telephone +44 (0) 870 129 8608
Fax +44 (0) 870 129 8610
Registered in England
Company Number 876412
Registered Office: Farnell House, Forge Lane, Leeds LS12 2NE
